digitizer help
xolo10
mcallen
hey can anyone help me. i recently changed the digitizer on my ipad 2 but when i turned it on the touch controls are all messed up. if i wanna unlock it i have to touch on the left sideas if the screen was rotated and its not. if i rotated it rotates again. i do hope someone can helps me and thanks for everything
scifan57
Regina,Canada
You either have a loose connection or the replacement digitizer may be faulty.
X
xolo10
mcallen
i have already checked the connection so i guess the part is faulty. thanks for your help
