Help with factory reset
Steve In Kent
I have just bought a used iPad Pro 12.9 1st generation.
I am trying to factory reset it without success.
I’ve tried Settings, Reset, Erase all content and settings
and it comes up with
Remove All Mobile Data Plans
This will remove all data plans from your iPad. Your subscriptions will not be cancelled etc.
This iPad hasn’t got a sim.
I have also tried the off/home button but it’s still got my name and all the apps
I’ve searched the problem but can’t find a solution.
Any help would be very welcome.
Milton-Freewater, OR
Since you don't have a mobile plan, have you tried just agreeing with the iPad to remove the mobile plan? If you're mistaken, plans can be removed and/or re-added through your carrier.
S
Steve In Kent
I have, nothing changes.
I recommend you contact Apple Tech Support. You can do this through their Support app, in the app store. Or if you are close to an Apple Store see if you can bet an appointment to bring it in for a diagnostic.
There is rarely a charge for this kind of issue, but if there is they will let you know before proceeding.
