Ipad 2 with usb hub
ovenison
Hello
I have an ipad 2 that I updated to 9.3.5 recently. I use a powered usb hub connected with a camera connection kit. The problem is when I try and connect it the ipad gives an error message say the usb requires to much power. I thought that if the hub is plugged into an outlet it would bypass try to use the ipad for power. I bought a different hub and i'm still having the same issues. Any ideas? Thank you.
Edit: It did workt before the update.
scifan57
Regina,Canada
Your second post on this same topic has been deleted as we only allow one thread for each topic.
I'm sure someone will be along soon to help you with your problem.
