Skip already read posts?
McDog
vermont
i am fairly new yo forums, and am overwhelmed with all the posts. and it seems each time i go to a thread, i have to go through posts i have already read. is there a setting that will show me new/unread posts only? i have looked through "forum help", but again was overwhelmed, and my search on "unread posts" didnt seem to come up with anything related to unread posts. OR.... is there somewhere else i can look to see JUST instructions on how to use forums?? thanks
J. A.
Apetlon, Austria
If you're using the app, you'll see something like this:
The blue signs tell you that there are unread posts in these forums.
Also, if you're in a forum, this will show you that you've read some of the posts, other ones still are unread (thread title in bold print, number of posts coloured):
If you don't want to read everything, (when you're starting here as member, there would be threads from 2011, 2012 also), you have the possibility to mark a whole forum as read. Open a forum to see the threads, then tap the arrow in the upper right corner:
This will appear, you may choose "Mark As Read".
Also in the app:
If you tap More (1), then Settings (2),
then go to Forum Reading Options - When Opening a Thread, Always
Tap it, you have three options:
HTH
M
McDog
vermont
thanks for the info. i had not been using the app, but will start. your post was very helpful.
leelai
Brisbane, Australia
Hi and welcome to the Forum!
A lot of us find the App much simpler to use.....below you will find a link to the app and a tutorial for it. Enjoy!
Tutorial for our App
http://www.ipadforums.net/new-membe...sistance/107524-ipad-forums-app-tutorial.html
Tutorial on creating posts on the Forum
