Does iCloud drain battery?
Ser Aphim
Philippines
Well pretty much title sums it up.
I think this information would help: I own an iPad 2, 16 GB Wi-fi only.
abababababab
Singapore
Just having iCloud turned on is not supposed to drain battery, but the battery might be drained, at a faster, though not at a significant rate when iCloud backs up your device contents.
J. A.
Apetlon, Austria
... which it does automatically when it's plugged in, so also no battery drain, except if you do this manually. :)
J. A.
Apetlon, Austria
I have an iCloud account, so Safari and other apps are synced. I don't notice any significant battery drain. Also, when you want to backup manually through iCloud, it just needs a few minutes (when you do this for the first time, it will need more time). No battery drain here as well. If you set up backing up automatically, then it will do this when it's plugged in, so absolutely no drain in this case.
Ser Aphim
Ser Aphim
Philippines
Oh ok. Thanks.
willerz2
New York
Can it drain? Yes, everything drains. Will it be a significant amount that you can see? Probably not unless you have data fetching/pushing from the iCloud email account.
Ser Aphim
Ser Aphim
Philippines
Oh! Ok. Thank you.
Thank you guys for the replies! Much appreciated as always from this forum!
