Dropping wifi signal
Hanne Rasmussen
Hi
Hope some can help me(mainly mom though), NOT that ipad Pro but can help with most problems.
But this is hard to crack.
When ever ipad is awoken from sleep, she has to Connect to wifi again, mildly pissing her OFF.
Been like that for a few months now.
Is there a fix or known problem?
J. A.
Apetlon, Austria
Welcome to iPad Forums!
Go to Settings - Wi-Fi on the iPad, select the network, and tap “Forget This Network”. Then join again.
If that doesn’t help, go to Settings - Privacy - Location Services - System Services, and disable Wi-Fi Networking.
If she uses a VPN service/app on her device, remove it and see if that solves the problem.
Otherwise you might have to reset her network settings (Settings - General - Reset, you’ll have to set up the Wi-Fi again), update the router’s firmware, or even restore the iDevice.
Hope that helps.
