iPad A1395 Battery Replacement Questions PLEASE
L
Leaky88
It’s totally repairable and is a common trap. If you’re not experienced at soldering I don’t advise starting with this repair. Check your local repair shops to see if they can do it. You may be looking at about $25 to $50 for the repair.
Brain,
Thanks. I don't know what the secret is to removing it. I studied and looked at it for the forever. Really is a sick feeling to see complete assembly vice just the connector. Leaky
scifan57
Regina,Canada
Brain,
The instructions in step 37 say to pull the connector very carefully straight up. Maybe you inadvertently used an angled pull which pulled the entire socket from the logic board.
L
Leaky88
Maybe. I cannot even see how it separates now that it's out.
L
Leaky88
Brian, It gets better. I got the socket free of the speaker plug but damaged it. I got it second hand because of a broken screen - the second one, I was told. I am not above a mistake, but the socket looked like it was distorted and it took a lot of effort to free socket from plug. Do you happen to have a part source for a single replacement socket? I realize almost everything is sold in sub-assemblies, but thought I would ask. Having worked Micro-miniature repair "years" ago, I'm certain a socket could be reattached to the board in correct setting. I know, it would be easier to quit, but if I do, it wins.
