iPad Air not charging
FairyNuff
Hi,
I have a problem with my iPad air not charging.
I just learned that Apple recommends running devices down once a month. Something I haven't been doing. I usually charge my devices overnight, so they never get the chance to run down.
Today, I put both iPad air & old ipad2 on full brightness and never lock, so they ran low pretty quickly. The iPad air got down to 1% before shutting off & the iPad 2 turned off at 4%. Then I put them both on charge. The iPad 2 has recharged now but the iPad air is not charging at all. It just shows the battery with the red line at the bottom. So I'm guessing it ran itself down too far and doesn't have enough juice to get itself charging again. Is this rectifiable?
Would appreciate any useful comments. Thanks.
J. A.
Apetlon, Austria
Hi, welcome to iPF!
If an iPad is very low on power, you're not able to use it for 20 minutes. The icon you'll see looks like this:
Apple Support
This means it's charging. So wait for 20 minutes, maybe this will be rectified by itself.
FairyNuff
FairyNuff
Ok, that is what it's showing, thank you.
I'll let you know if it's successful.
J. A.
Apetlon, Austria
You're welcome.
I'm keeping my fingers crossed that waiting is all you need to do. :)
FairyNuff
FairyNuff
Thank you so much. The wait was worthwhile, and it's charging as it should now.
I was a little worried that I'd damaged it!
