iPad “cheat sheets” for keys other than CMD?
Padcatt
So, I just learned (goog’d) that CTRL-D is how to forward delete on iPad.
Unlike the CMD key, pressing down CTRL does not invoke that transparent layer revealing all the things you can do in conjunction with CTRL key.
Is there a sheet or document somewhere which spells out all keyboard tricks possible on iPad?
giradman
North Carolina
Well, I rarely use my BT keyboard with my iPad, so have not explored the various key combos - but for starters, check out this Apple Support Article - a google search using some well chosen terms would likely bring up a lot of hits. Good luck! Dave :)
Milton-Freewater, OR
Holding down the Command key reveals all available keyboard shortcuts, not just those invoked with the command key alone. What shows is based what is currently available. For instance, you won’t see text editing shortcuts if you aren’t editing text.
There are a lot more available shortcuts in iPadOS 15. Be sure to scroll right to see them, or use the tabs below the shortcuts to select the options,
