iPad Model A1219 as external display for iPhone5C?
LivsMom
Boston, MA
Hello all,
My first post... :)
I'm hosting a 50th birthday party and have purchased a Bluetooth enabled speaker system and a bunch of mics and adaptors in order to create a karoake/toasting platform. The unit enables you to sing along with any track on your Bluetooth enabled iPhone, iPad, etc.
I would like to be able to Google lyrics and display them on my iPad screen. The challenge is that the party is taking place at a location where there is NO internet access available (even via WiFi). So, my strategy was to figure out if I could do the Google Searches from my iPhone and then display them on an iPad model A1219. (I also have a newer iPad mini but I prefer the larger screen of the older iPad).
Is this possible AND optimal using a Lightning to VGA Adaptor? And/or, can anyone recommend a better/simpler/more practical solution?
TIA!
-Andrea
scifan57
Regina,Canada
Hello all, My first post... :) I'm hosting a 50th birthday party and have purchased a Bluetooth enabled speaker system and a bunch of mics and adaptors in order to create a karoake/toasting platform. The unit enables you to sing along with any track on your Bluetooth enabled iPhone, iPad, etc. I would like to be able to Google lyrics and display them on my iPad screen. The challenge is that the party is taking place at a location where there is NO internet access available (even via WiFi). So, my strategy was to figure out if I could do the Google Searches from my iPhone and then display them on an iPad model A1219. (I also have a newer iPad mini but I prefer the larger screen of the older iPad). Is this possible AND optimal using a Lightning to VGA Adaptor? And/or, can anyone recommend a better/simpler/more practical solution? TIA! -Andrea
Your iPad cannot be used as an external display for your iPhone. You can, however use the personal hotspot feature to generate a WiFi hotspot with your phone, then connect your iPad to the internet using the WiFi signal from the phone. Of course, if your cellular carrier does not allow you to use the hotspot feature this will not work.
KevinJS
Edmonton AB Canada
Only thing I can come up with is mirroring through AppleTV. It works, but I'm not sure about using your phone's hotspot.
L
LivsMom
Boston, MA
Thank you both for your suggestions. After a lot of research, I've decided to purchase a Verizon MiFi unit to use as a hotspot for the party. Fingers crossed that it will work! I truly appreciate your responses. Thanks again!
