Ipad Pro (Usb C) do not match audio/midi devices.
Fablues
Hallo.
I was able to use my iPad Pro with lightining connection as an expander.
Now I own an iPad Pro 11”, 3rd gen., Usb C, and ther’s no way to do the same.
It seems it is not capable to transfer midi and audio data.
I would like to ask all of you for confirmation that this is a well known fact.
Or what? Do i miss something? 🫤
Thank you
Milton-Freewater, OR
There are quite a few adaptors for USB-C that will work for older equipment. I searched for "USB-C to Lightning female" on Amazon and found several hits that claim they will work with various audio and midi devices. I'd double check with your device manufacture before buying, but it should work.
Outside of old Lightning devices, USB-C supports a wide range of external devices including MIDI, and audio. If you can't find USB-C devices you like, USB-C to USB-A adaptors are common and cheap.
