New battery
Geraldo32
I recently installed a new battery, and it discharges when tot in use in standby
I have aipad air 2 also with new battery both
The batteries wete bought from different companies with a good reputation
I have has a few ipad airs with the original batterys and they do not discharge they hold there charge like normal
The new batterys i bought have got 100% battery health so they cant be faulty
I tries a dfu factory reset on itunes but problem is still there
The ipad still performs well it lasts 12 hours watching a youtube video streaming
Dont know what it is thats causing it, i have tried resetting the settings but its still draining
scifan57
Regina,Canada
Maybe you accidentally caused a short inside the iPad when charging the battery? How quickly does the charge level drop when in standby?
scifan57
Regina,Canada
Does the battery still drop that fast if the iPad is turned off instead of being left on standby?
G
Geraldo32
I tried turning it off for a day and bsttery is showing 91 % now yesterday it was showing 88%
scifan57
Regina,Canada
Try running the battery all the way down then charge fully. Don’t use it while it’s charging. This should calibrate the charge indicator. Let us know if this helps.
