News stand problem, magazine not opening
farahif
Hi guys. I purchased a magazine today from newsstand on my ipad2 and every time I try to read it the screen stays black and the magazine doesn't load. Do you guys have any suggestions as to what I should do? Please help...
Milton-Freewater, OR
Go to the magazine's App Store page, click on the developer's support link. At the least they should have an email form you can use to ask what's going on.
Other than that I recommend the usual fixes, if you haven't already done so. I'll post them below.
