No volume while charging
JoeTEMT
NJ
I bought a new charging cable for my ipad2 from an aftermarket internet company! It charges well but I can't near any
Sound until,I unplug it! The original Apple charging chord allowed me to listen while charging! Is it because I bought a cheap charging cable and not the original Apple one! Thanks
Milton-Freewater, OR
Maybe.
The 30 pin connector has audio out pins. If the charging cable is shorting them, so it looks like a speaker is attached, then the audio from the built in speaker will be turned off.
giradman
North Carolina
Hi Joe.... - I think that our iPad Guru, Twerppoet, has the explanation. As you likely know, there are a number of AV adapters for the 30-pin docking station of the earlier iPads - I have one that uses an HDMI adapter which will output sound - so looked for a diagram (attached) that might show the purpose of each pin - audio is carried out on several of the lower numbered pins (which as already stated will mute the sound from the iPad speakers) - the important message here is to buy 'quality' accessories for your iDevices - saving a few bucks might not be the best solution - just saying. Dave :)
leelai
Brisbane, Australia
Hi and welcome to the Forum!
This is the first time I've heard of this.....great info Twerppoet and Giradman! ......I hope you can return that charger!
http://itunes.apple.com/us/app/discussion-forum-for-iPad/id412896524?mt=8
Tutorial for our App
http://www.ipadforums.net/new-membe...sistance/107524-iPad-forums-app-tutorial.html
Tutorial on creating posts on the Forum
http://www.ipadforums.net/new-membe...1590-tips-tricks-those-us-who-don-t-know.html http://www.ipadforums.net/ipad-os/49581-ios5-tips-tricks.html
