Problems with iOS 13.4.1 update
Chris Hall
I updated yesterday and there was no problem. However, my iPad Pro 10.5 inch is now more or less unusable! A few minutes after booting up it is shutting down and then re-booting of its own accord. This happens over and over again. Any ideas please?
J. A.
Apetlon, Austria
Welcome to iPad Forums!
Here are a few things to try:
If possible, update your apps between those boot loops, and make sure time and date are correct.
If that’s not an option:
Try restarting your device, and if that doesn’t help: force start it.
Connect your device to a computer and update it via iTunes (PC) or Finder (Mac).
If that doesn’t work, put it into recovery mode:
If you can't update or restore your iPhone, iPad, or iPod touch
C
Chris Hall
Many thanks. I’ll try this tomorrow.
