Atomic Web browser problem
bbmountain
I have been using the Atomic Web browser for quite a while now (the paid version.). I don't know how I did it, but I've lost the whole area at the top of the screen! Where the settings button, address bar, google search bar was is just now white space. I really don't want to uninstall/reinstall as I have it all set up the way I like. Any thoughts?
Actually I didn't have the arrows down on the lower right either! I did a complete shutdown/startup and that seems to have fixed the problem...I'm glad :-)
3 finger tap puts the browser into and out of full screen mode.
I am sure this was it. Then, because it is multitasking aware it didn't really restart until a reboot. I love the three finger full screen gesture. Btw, the gestures make this a GREAT browser.
DaveR
The only reason I don't like this app is I can't post on the forum because it won't bring up the keyboard in the post box....
I had it once when Jumping to it directly from Safari
I set up a special bookmark in Safari, so when I want to see a page from safari in "Atomic" all I need to do is give a little tap on the bookmark, and the page pops up on the much better browser - The Atomic.
I have it, but I don't use it that often because I think it is way too finicky when you want to long-tap a link to open in another tab. You have to be really still!
Common problem for many iPad browsers with a simple fix, go into settings and change browser ID to Mobile Safari for iPad or something else other than the default. Then most forums will recognize the browser properly and let you edit text.
Using Atomic to post this message in fact.
Got the same problem here, but changing the setting as mentioned here, i started to get the keyboard. In fact I am answering this post with Atomic.
just above the talk box in the top right corner is a box with AA in it tap that then it will allow you to enter text.
Is there any way to print via Airprint with Atomic?
would like to see this.
I confirm this
The setting "identify browser as..." is the key
My last ~60 posts were made with the atomic browser.
Things I love about Atomic:
-tabs
-no reload when switching tabs
-private mode
-search within page
