Battery problem with ipad2?
Did some testing
I have both versions of the iPad. I noticed right away that the iPad 2 seems to drain much faster. I made sure the setting on both were the same. I charged both of them fully. I then unplugged them and let them sit turned off for 6 hours. The 1st version was still at 100%, while the iPad 2 was at 80%. That doesn't make any sense. I would love some feedback and some answers. The only thing I can think of is that the OS on the iPad 2 is using the battery up. The 1st version has not been updated. Any thoughts?
I had this happen with my original Ipad when I upgraded from 4.2.1 - 4.3. I fixed it by draining the battery till the Ipad shut off and then doing a complete charge. After the battery was calibrated I did not have any more problems. When I got my Ipad 2 last week I ran it the first time until the battery drained completely then did a full charge and it will stay at 100% off the charger for 8+ hours without being used, wi-fi and push notifications on
Are the people experiencing differences between iPad and iPad 2 early buyers of the iPad? Did they have to break in their iPads, It seems that the iPad 2s are so factory fresh they haven't done any of the typical pre-breakins on the battery that you find in most consumer goods.
Ping
Don't forget PING was added in one of the later OS updates and it is a known battery drainer. Go into restrictions and turn off PING.
Fucking Ping. :mad:
I hate Ping(latancey) in my video games and I hate it in my iTunes. It also rimes with Bing.
How do you enable restrictions
When I try to enable restrictions in order to turn ping off
it asked for a 4 digit passcode? Where do I get the passcode?
Assuming there where no restrictions before, does it ask you to set a 4-digit passcode. So all you have to do is pick any 4-digit code you like and enter it twice.
Excuse my ignorance as I am new to Apple/iPad 2, but what exactly does Ping do?
EDIT: Ignore me I have just found out.... I have now turned it off :D
I took the ipad2 to the Apple store as suggested, but the best I could get from the geniuses there is that a 1% to 2% drain per hour during sleep is normal.
Same here...
So, if 1% to 2% battery drain per hour in standby mode is normal, I can't see how they advertise that the iPad 2 have one month standby time... :confused:
Batnun
ipad 2 battery drainage
i charge my ipad overnight then put it on sleep, after 8 hours it's still on 100% but when i use it the battery drains very fast for example on brightness a bit less than medium, when i watch a movie on avplayerHD, 1% in 5 minutes. i can't understand if this is normal
Same here:( never saw with my pad 1?
