Camera connection kit and iPad 2
nicolemaher80 said:
I plug my camera connection kit into my iPad and nothing happens. Does anyone have a trick?
Hi and welcome to the Forum!
Regarding your question, do you have your camera hooked up with its own cables to the CCK, the camera also needs to be on, or are you using an SD card?
nicolemaher80 said:
Both my cannon and the sd card and the iPad does not respond at all.... Btw thank u for responding.
That is unusual, I have the CCK and use it with a Sony camera. When you hook up I assume you have the iPad and the camera both on, I have my iPad set up with the photo app open also. Try these steps and see how you go - do the four finger swipe up or double press the home button to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it. It's also a good idea to close all these apps, as it helps the iPad run smoothly, I do mine every night. Check and see if it is operating now, if not a restart is in order.
When an App or your iPad begin to behave strangely these are the first steps you should do to rectify it. Let us know how you go, good luck!!
nicolemaher80 said:
I tried shutting down all apps and restarting with no luck. It does not respond at all to the sd or camera :(
How old is your camera, I wonder if it could be this although if it can connect to a computer why not here. Your SD card should work though, has it come straight out of your camera? As all images on the card must be signed as a photo usually is for the iPad to recognize them. Have a look here-
http://www.ipadforums.net/ipad-general-discussions/5227-ipad-usb-flash-memory-card-2.html
Hopefully someone else will chime in here who knows more.
