Camera connection kit problems with iPad2
Coinin
I used the camera connection kit perfectly well with the iPad 1. I recently tried to use the same kit with the exact same camera on my new iPad2 and it will not download the photos. It gives some kind of error message (exactly what I can't remember- something about the card may be corrupted, but the SD card in camera is working fine.
I have shut down my iPad in the way you describe several times since I had this problem. Am I right in believing that the camera connection kit does work with the iPad2 then? I don't need to purchase a new one?
Compatible Camera Kits
I'm sure I've read that some cam kits are not iPad2 compatable.
This one for instance is not compatable here:
2 in 1 Camera Connection Kit SD Card Reader & USB iPad | eBay
This one: Apple iPad Camera Connection Kit (MC531ZM/A), available locally or on Amazon, has worked with my IPAD2 for SD cards. I haven't tried the USB feature. Apparently, this used to work better, but Apple didn't want people to use the USB feature to import other files, so they crippled it - so it may not always work with your camera that way. But the SD support is very good - slick, and easy to use.
J
Hi Coinin - I bought into the iPad2 and the CCK (Camera Connection Kit) recently; seems to work fine for me on the newer iPad - not sure if Apple decided to change the specs as mentioned in other posts here?
I'll be curious as to the responses - :)
I also have an ipad2 and the apple camera connection kit that I have used without incident. I have heard of some people having issues using the USB though, and I'm not sure but I think it may be related to a power issue. I know the USB connector can be used with some flash drives etc that squire an extremely low amount of power to operate. The power output on the iPad is very low and as such, can not sufficiently power many devices. Being that you are using the camera, though, one would think that the camera would supply the power for the transfer of data. I have used my USB connector with success from my canon t1i, but with no success on one of my USB flash drives.
I have the Apple camera kit and the MIC Store camera kit for compact cards. Both have worked very well both with the cards and the USB port with my Canon 40D camera. I have an IPad 2. I purchased the MIC because I like the direct connection of the card rather than to fumble with the cable.
http://store.micgadget.com/card-readers/280-ipad-2-cf-card-camera-connection-kit.html
I used these to upload in excess of 5,000 photos so far, usually to be able to look at them when traveling and as a form of back up during the trip.
Sent from my iPad2 3G 32 gig / using iPF
Thanks for the info! I have been wondering about the MIC kit. I like that it is all in one connector rather that 2 different ones. Perhaps I'll check it out. Did it take long for shipping?
It took maybe 3 to 4 weeks - I do not remember exactly - but they had sent me an email to inform me that they were out of one component and were a little behind. If you use compact cards, you will like it even if your camera connects ok to the USB port of the kit.
hi coinin, i used to have this problem before it's because u have un-locked ur ipad2, i will pm u the procedures and link to the solution..
I just bought the connector but when I put it in with my SD card, I don't see where to import my photos. Can someone tell me where to look?
IPAD recognizes camera SD cards by the default directory in which the camera puts the photos. I tried just copying photos to an SD card, and Ipad didn't see them, but if I pulled sd from camera, it worked fine. Of course, you could simoly copy photos into the directory where the camera had been putting them...
Good luck,
Joe
I purchased a sd card reader which worked brilliantly first time then refused to work again,read all the posts on here and took the card reader back to HMV where it was purchased from and tried about 10 more all of which didn't work.Then took iPad to John Lewis where it was purchased from,the guy did a couple of tests and said it's the iPad at fault.Seems it's quite a common problem and they exchanged my iPad for a new one.
Great service from John Lewis,better than apple who didn't want to know!
