charging problem
gurminderraman
sir,
i have problem in my ipad3 sometimes its not charging
tell me sir what's problem, charging wire proble or others
please solve my problem as soon as possible sir.
thanks
Are you trying to charge it from a wall socket or by the USB on a computer.
From what I have read on this forum they do not charge well on a computer.
Darkangelwitch (Surrey) I luv my iPad
ok sir i try thanks
but sir if i connect with my laptop its all data safe or gone ,because i didnot connect my ipad before with laptop tell me thanks
gurminderraman said:
ok sir i try thanks
yes sir i always charge with wall socket.but one more tell me sir if i connect my ipad with laptop its all data delete or safe ,because before i m not connect my ipad with laptop . thanks
1. Charge using the provided charger.
2. Your data is safe, follow instructions.
I just wanted to add this, you can charge with a Laptop or Desktop PC. Just download ASUS AI Charger (Free), download and install, and reboot your system and you will be able to charge it through Laptop or Desktop PC, just ask me for assistance, and your data is always safe.
I have problems charging mine a lot from the wall. I have to check it multiple times to make sure its charging and it always takes for ever!
Maybe your wall socket is not giving off not enough juice for your iPad? Does it have the lightning icon on the battery?
Does your charger look like this?
If not you have the wrong charger.
<img src="http://www.ipadforums.net/attachment.php?attachmentid=20805"/>
It depends. There are different type prongs for a different country like Europe, Hongkong and Australia. As long as it is an original Apple product.
I think the iPad 3 needs a 12v socket, but as far as I've seen, the most common volts that is supplied in a wall socket is 10v.
Actually the input voltage Is a variable of 110V-240V, the prongs can be interchanged for various countries.
We run on 220V here in South Africa.
yes same like this charger which one u shiw the picture,usb cable charger , but sir some times working some time not working i cant understand thanks
