Forum Help and Questions
MoneyGuy said:
When I store webpages by touching that little icon on the top left, it seems I can only store nine pages. Does it store more than nine?
the 2 square icons 1 ontop of the other is how many windows/tabs you have open, the right arrow icon allows you to bookmark, save to home screen, email and print
icouldsave.co.uk - help save money and the planet!
To store/save websites, you would click on the rightpointing arrow and select 'Save bookmark'. The two overlapping squares opens a page of currently opened tabs, of those only 9 can exist at a time. This restriction can be circumvented by jailbreaking though.
Posting
What does it say when you try?
It says on the list at bottom of page "you may not post new threads"
....where is the link or choice to post a new thread,? ....maybe I was in the wrong place. Knave been too busy to be on forum lately, now I have a problem......when I touch a picture the save image doesn't appear. Also when web pages are loading the pictures do not load until I touch the screen and move it a little. weird right? Thanks for help! Jeanee
SweetPoison said:
Go to Private Messages under your ID/Name, top right side ~ then on the left under Options and Settings, you will see Change Avatar.
Follow the steps there, but if you need further assistance just pop back!
Good luck!
Why can't I see this? I don't see "change avatar" anywhere :-(
Remember you need to be on the web site to change your avatar. Not the app.
Open the web page, login with your user name and password.
Locate "user cp" at the top of the page.
From there, you can upload your new avatar, and change other settings.
Remember, this can ONLY be done from the web page.....The app does not have the extended features :)
Thanks jeff! I never would have figured that out!!
problem with my account, when I click on my name it changes my forum nick to "MartinD28" location "Florida" etc
Any ideas? my user name should read Martin.D once clicked..
Thx
Thx
Indeed, you are right, bizarre - I will get Admin to check this out!! Sounds like a 'glitch' to me....
SiuperMods can't do anything with names on the accounts. Those should be forwarded to admin to have them looked.at.
