Hello J.A. and All!
Well, J.A., looks like we (couldnāt have done it so fast without you!) put a stop to the hacker using TV Provider on my iPads! Yay!
But, today I have two issues to take care of, namely, (remember Iām using a 5th Generation iPad, if it matters?)
- I canāt turn on Location Services. I usually have it turned off, except for a very few apps that need it, e.g. taxi services like Uber, OK? The path I used was Settings->Privacy->Location Services. I went there, and the toggle switch beside Location Services was faded and would not toggle at all. Nor will Location Alerts toggle (faded) and Share My Location does not respond. I looked at the User Guide, it tells you how to use Location Services, but not what to do if itās not working normally!
The only thing I could think of was Settings->Reset->Reset Location and Privacy. Reset Network Settings *could* be a (probably distant second) choice.
Iām wondering if Iām on the right track or if someone has a better solution? Thanks!
________________________
2nd Issue
If you go to Settings, the left hand pane has lots of Apps. Tap one, and details are shown in the right hand pane. One option on the right side is āBackground App Refreshā, with a toggle beside it. For most (I think all) of these Apps, the toggle on my iPad is faded- same like Location Services, above. It doesnāt seem to matter if itās a native Apple App, e.g. Stocks, or 3rd party Apps like Wikipedia or my VPN.
BTW, just in passing, Background App Refresh, I assumed, kept the App running in the background, to be always up to date. Does it have any other effects on the iPad?
To conclude, I have *no idea* how to enable Background App Refresh. If someone does, I would be extremely grateful if they could share their solution with me!!
Thanks again!
p.s. How can I get rid of this miserable so-and-so? Really! Iāve had enough of this nonsense!
2nd Issue
Thanks again!
