Help Help Help - why do I get this message when sending a message using live.con
ThePhotog
I've reset my passwords in settings several times yet every time I send this email I get the follow message " a copy has been placed in your Outbox. Sending the message content to the server failed". Then it's prompting me to click on OK.
I am using MailShot to enter the email addressees in groups, I've never has this problem before but I have a upcoming funeral to get a Color Guard email of directions out
Guys Please Help
Tim,
I did as exactly instructed in your reply and got the same error message..............
Tim,
Sorry to hear that. I sort of knew it wouldn't be that simple....
Can you send other emails OK? i.e. could you send a test email to yourself? I'm asking that because I'm trying to understand whether it's something with that particular message that either the iPad or mail server doesn't like or whether it's a mail server or iPad problem - i.e. it won't send *any* email.
A further question - I use MailShot a lot too. Have you emailed to this particular mail group before successfully? If not, I wondered whether one of the recipients in the list is incorrectly formatted - so, for example, instead of '[email protected]' you accidentally typed 'john_doe&hotmail.com', which would cause the server to reject the message.
Emails are usually placed in the Outbox, if the email provider settings are wrong.
For instructions to setup hotmail properly, please follow the link:
http://thetechjournal.com/electronics/iphone/steps-to-set-up-push-hotmail-on-iphone.xhtml
If you can send single emails from your live account, but not group emails, then perhaps the group-send app is not working properly, or the app behaves in a way that makes it appear as if it were sending spam-emails.
I cannot send an email to myself - I get the same error message
Don't understand my iPad. The link you sent won't stay on the link after opening it ..
Ok, then it seems as if the mail settings are wrong.
Have you followed the above linked instructions? Even though they are for an hotmail.com account and you use live.com it should be the same, as both use the Microsoft email server. Just insert you @live.com address whenever the instructions advise to insert your @hotmail.com address.
Edit:
The link works fine for me in iPF, did you scroll down below all the advertisement?
However I am receiving mail. Go figure
I wondered if it was something as simple as their email server being down. They have physically different machines for ingoing and outgoing mail. So, if you have another email account, maybe it would work OK if you used that one instead. Obviously you have urgent emails you need to send ASAP so you can't really wait around to see if they 'fix' the SMTP outgoing mail server (even if that is the problem).
You could simply 'sign up' now for a gmail account at no cost....
It might not 'solve' the original problem, but it might be a work around to get this urgent emails out...
I tried in gmail setting it up. Won't work error message about gmail and password.
Just another thought - don't get cross if it sounds stupid - it's 5.30 am in Scotland....
Are you trying to send these emails from a location you've not sent from before? i.e. you normally send from your house but now you're trying to send and you're in a hotel or something like that? If so, this could be the 'infamous' Port 25 relay problem, where email service providers will not allow you to send email from an 'unknown' location. When you're at home, your service provider knows who you are because you have logged in to use your network.
But, if you're trying to send an email from a 'foreign' location across the Internet, the 'standard' SMTP protocol does not require a password to send an email, so service providers will not allow this, because they have no way of knowing who you are and you could be 'pretending' to be someone else, if you just know their email address.
