HELP How to connect Brother Non AirPrint Printer with iPad2
reefer
USA
Hi,
I am newbie with iPad and trying to connect my non airprint printer with my iPad2
I've installed the iPrint&Scan Apps from apps store but still not able to connect. . It says I have to makesure the machine and iOs device are on same network.
The printer manufacture and type is Brother MFC 5460CN , and I do not have the budget to replace with newer / compatible printer at the moment. Is it possible for me to print from iPad ? if yes Would somebody help me guide how to set it up the right way? Thank you so much .
Hi Reefer - welcome to the forum! :) Please provide some further information: 1) Assume you have a computer - if so, please provide brand/model/OS installed?; 2) Home network setup - type of modem, router, and ISP?; and 3) If your printer works w/ your computer (please verify), is the connection wired (how) or wireless.
I'll stop there to let you answer - your printer is not on the 'AirPrint compatible' list on Apple support, so another solution is needed; also check the Brother Website - there may be an explanation/directions there or web-based support (I recently exchanged emails w/ them trying to get an older brother laser to work wirelessly - failed but they were responsive) - good luck! Dave
Hi, I am newbie with iPad and trying to connect my non airprint printer with my iPad2 I've installed the iPrint&Scan Apps from apps store but still not able to connect. . It says I have to makesure the machine and iOs device are on same network. The printer manufacture and type is Brother MFC 5460CN , and I do not have the budget to replace with newer / compatible printer at the moment. Is it possible for me to print from iPad ? if yes Would somebody help me guide how to set it up the right way? Thank you so much .
Hi, reefer! Welcome to iPF!
The app doesn't support printing with your printer. Sorry!
You'll have to look for other ways to print files from your iPad.
Hi and welcome to the Forum!
Have a look at this thread and in particular Twerppoet's great post on printing from an iPad......I hope it helps you!
http://www.ipadforums.net/new-member-introductions-site-assistance/117474-air-print-eprint.html
Tutorial for our App
http://www.ipadforums.net/new-membe...sistance/107524-ipad-forums-app-tutorial.html
Tutorial on creating posts on the Forum
