Help
fatima
i have 2 ipads and they r both syncd to my itunes account on my laptop. one of them is for my kids. the problem is now when i download apps and sync it to the kids ipad i dont have the option of choosing the apps that i want transferred to them. i used to be able to do that before. but now the whole thing is fadded out and i cant click on anything. what should i do ?
thanks.
You need to choose to manually select the apps you want to sync. I sync my iPhone, iPad and an older iphone for my granddaughters apps, all on my computer. Each has their own set of apps.
i know what u mean but the tick box to do that is faded out so i cant click on it. any idea how to get it back to normal ?
thanks
Do you have the checkbox for sync apps manually checked? If you have "sync all apps" checked you won't be able to sync them individually.
I don't have iTunes in front of me because I'm at work but I Will check when I get home if someone hasn't answered you by then.
