OP OP Amp1216 iPF Noob Mar 24, 2012 #3 yof said: is that cydia? try re-install cydia with redsn0w Click to expand... Now cydia won't even come up so how do I reinstall?
Y yof iPF Noob Mar 24, 2012 #4 once you re-install. try restarting the iPad or if you have option to respring it.
OP OP Amp1216 iPF Noob Mar 24, 2012 #6 gresh14 said: Did you try a simple respring? Click to expand... Yes I tried reboot respring not a complete shut down should I try that?
OP OP Amp1216 iPF Noob Mar 24, 2012 #9 yof said: Yes did you try it? Click to expand... Wow the one thing I didn't try worked thank you for the comment I would have never tried that
