i saw somewhere on the net once some suckers that go onto a window, you then connect them with a jack plug to a music source and the window becomes the speaker
I'm so interested in such stuffs and search about them on the Web.
I think the apple-like speaker somewhat used the planar speaker technology. A planar speaker can be in the shape of a frame and also other shapes. And the following is an illustration on how such a speaker works.
The vibration plate is actually a flat panel made from some selected materials. When a flat panel speaker is electrified, its magnetic-material-made exciter begins working to trigger off some complex wave motions on the panel, through which, sound is sent out.
According to some reports, a flat panel speaker performs better in terms of fidelity than a conventional one, which, in the shape of a cone, often produces twisted voices -- a conventional speaker compresses voices before sending it out. Besides, a wide angle or a long distance between a flat panel speaker and its user doesn’t impair his enjoyment so much, because the stuff emits HiFi sound waves to more directions (voices are spread more evenly).
If the speaker you linked adopted the flat panel technology, the button on the bottom should have served as a an exciter and the desk played the role of a vibration plate. Am I right?
There is a story about the derivation of flat panel speakers, by the way. At then end of the 1980s, researchers of the UK Ministry of Defence tried some flat composite materials to conceal military helicopter engines, in an effort to lower noises. But the noises were not impaired. Moreover, these materials make sound by vibrating, just like a loudspeaker. Then the researchers began the R&D of flat panel speakers. And established in 1996, NXT has long been devoted to the field.
