twerppoet70
If the earlier suggestions in this thread did not work, then it is probably a hardware problem. No matter what product you use, there are always some hardware failures; even if you never drop it.
If the iPad is less than a year old, or you have AppleCare, then you should still be under the hardware warrantee.
https://selfsolve.apple.com/agreementWarrantyDynamic.do
Apple should repair or replace the iPad for free. If not you'll have to pay to have it fixed; either through Apple or a third party repair facility. Be sure to research any third party repair to make sure they are accredited and reliable.
Edit: I don't see your country/location, so you should double check the warrantee info. Some countries have mandatory two year hardware warrantees.
