That's great to hear. Glad to help!![]()
I just tried it again and it's doing it what could be causing this.
Have you turned on your auto fill?
Go to Safari>auto fill and turn on and enable username and password feature. Try that. You may have to put in to user name and password again, but give that a try.
Yeah I tried to turn that on but it doesn't do anything.
Gosh, the only other thing o would suggest is a reset of our your settings.
Go to General>Reset>Reset all settings. You will than have to re-enter all of your log in information again.
Just to make sure, that you are running ios 6.0.1 and that your device isn't jail broken?
This thread reminds me of an old joke. Of course the system analyst side of me always quantified the joke as so;
Patient: "Doctor, it always hurts when I do {x}."
Doctor: "Then stop doing {x}."
So eddieg your issue brings up two major questions.
1) Why are you doing it?
2) How are you doing it?
The first is to find out if there is a better way to accomplish your goal. The second is to figure out how to reproduce your observed effect. And here is where you have to make sure you don't miss a single item in your description. Because I need to literally know every single step you do to make this condition happen. Off the top of my head there are three unique ways to get from the Safari browser to Settings and then back the Safari browser. So please describe in detail how you are doing it.
Also how often should you clear cache and cookies?
Ok when I go to settings and tap on safari and clear cache then go to home screen open safari and go to a forum and log in browse for a bit then exit by tapping the little x in the top left corner then going to the home screen let the iPad go to sleep come back 10-15 min later go back to the forum I logged into 10-15 min ago and I have to sign in again. After the 2nd sign in it will remember my info. This happens with all the forums I belong to. It doesn't do this with my iPhone 4 BTW it's an iPad 4 IOS 6.0.1 thanks for your help Skull.
Ok 1 2 3 yes for 4 it's a 5 is yes 6 7 yes 8 9 yes 10 no 11 12 yes 13 time out 14 Smart Cover 15 16 yes. Yes I get asked to use the forum app again.
