I need help buying an hdtv
HKWrite12 said:
Is it cheaper? Do you think it's better!!!!?
It's about between 60-90 dollars depending on model... But I wish it supported AirPlay... I bought it mainly for Netflix though and it's wonderful for that
Right now, I'd buy the apple tv..
If I win the lottery I'ma get the biggest one with 3d and wifi and web apps. And a wall mount.
Since that's unlikely, I saw a lg plasma 50" 720p that I liked for like 700
Or a VIZIO 1080 42" for 400.
It won't be for a month or so but I'll definitely update. And I'm going for apple tv too.
So I finally bought the TV yesterday.
it's a Vizio E422VA - 42" VIA model. 1080p, 60mHz.
I am getting a Linksys WRT400N router to connect my lappy, Padi, TV, and future iPhone 5.
This VIA is the first of its line so it isn't compatible with the bluetooth remote, but is there an adapter I can buy to make it compatible and so I can listen with my new Motorola s10-HDs?
Sent from my iPad 2 using iPF
