I need help how to jailbreak ipad 2 4.3.1
I edited your thread title. There is no need for 34 question marks.
You also can read many stickies posted in this section with regards to jail breaking.
I've moved the thread to the main hacking section.
If you look at the jailbreaking methods sticky post you will see that unfortunately you cannot JB your iPad2 as it stands. Unless you have already saved blobs for 4.3.3, you are completely out of luck. Sorry.
If you do not have SHSH blobs saved for iOS version 4.3.3, then no, there are no [other] options for jail breaking an iPad2 (as f4780y well stated).
