I received my iPad 2 3G a couple of days ago. Shortly after I started using it, I was asked if I wanted to install iBooks to which I responded "yes". It seemed to install but the icon is greyed out, it says "waiting..." underneath the icon and it will not open. When I look in the app store, it says it is installed.
Apparently, because it is a basic Apple app, I can't uninstall it. So, therefore I can't try to reinstall it. I've asked Apple for help and was sent a bunch of links about how to USE iBooks which does me no good as I can't even open it.
Can anyone help?
Thanks, Ed
Can anyone help?
Thanks, Ed
