Infinity blade crash
I deleted the app and re-installed it. It crashed at startup. I reboot the iPad and started it again and it ran past the intro. As I suspected, I lost my saved game (lvl 43). I played one battle and after I won, it crashed. I haven't been able to get it to not crash since then.
POSSIBLE FIX (you must have infinityblade all the way updated)
i found a possable fix bust you must have the newist version of infinityblade and you must be jailbroken with SBsettings installed. so what you need to fix it is to use sbsettings (which is were you slide the top bar or status bar at the top of your screen. what you will do is hit the small power button located in the sbsettings menu. then when you press "power" it will bring up a list they will say 1.reboot 2.power off 3."""SAFE MODE""" 4.lock what you want to do is select safe mode this will disable all un nessasary prosesses running in the backround and make your apps run in compatibility mode. now open infinityblade and it should now work!!!!!!!:o:o:o:o:o:ipad-keyboard::ipad-back::ipad-peacock::ipad-front::ipad-movie:
I try this, and it work one time, after that not work anymore, anyone know what the problem is? I realy want play this game :(:(:(
This is a known bug already and isn't the iPad's or iOS' fault, it's just a bug.
Sent from my interestingcompanionPad using iPF!
it doesnt work because some apple products see that when the app is executed.(it starts eating up all the ram and procces) so any way when the device see's it starting it goes WOOOOOWWW ineed to clear up resources so it starts dumping everything running and result is the app crashes.(NOTICE HOW THE APP CRASHES WHEN IT EATHER GETS PRESSED ON OR WHEN IT REATCHES THE SCREEN WHERE THE PLAY BUTTON SHOULD COME UP TO START THE CHALANGE.) THIS IS JUST A PROBLEN WITH THE HARDWARE IN YOUR DEVICE. i brought mine into the apple store and told them what it was doing and they craked it open and said the RAM was faluity.( meaning that it would work but when it would reach near 95% load it would fail and reset. explaining the crash. so thats explains whats happening. SOOOO............... ya. and for the one time working thing. it is because the ram starts running at max and heats up NOT roiling hot but gets warm which is normaly the cause of this fault.( YOU CAN BLAME APPLES MULTITASKING ON THAT ONE. ONCE YOU CLOSE AN APP IT SHOULD KILL THE TASK BUT IT DOESNT KEEPING IT RUNNING.) so yaAAAA.:):ipad-back:
I know right
Tell me about it, i have a saved game (level 89) and I'm trying to decide whether I should do what you did. Sure my game might stop crashing and I'll actually get to play the game... But having the saved game and not being able to play it is just as bad as losing it... Summary: I'm screwed.... Any suggestions..... Please!!!
I had same issue when i first downloaded this but after new update havent had any problems so far
Sent from my iPad
Sent from my iPad
I was hoping that would help me but it didn't I just redownloaded it and now it works, but I lost everything but its been 2 days and I already have over 4 million money. I found a good system
Hold down power button till it reboots
Hold down the power button till iT reboots? Been playing the game since.....level 43 and going strong
Is there there a way I can get it free..? Or get it from some one...?
I don't know if this is a good or the right thread to ask this in, but my "Michael Jackson: The Experience" game crashes after the game closes, why does that do that? How could I fix it?
Give these steps a try-
Do the four finger swipe up to reveal your multi task bar along the bottom. It will show all the apps that you have opened at one time or another. Long press one of these apps until they start to jiggle and red minus signs will appear above them all. Press all the minus signs, this will close them, not delete them. It's a good idea to do this regularly just to keep them all running smoothly, I do mine every night. Check and see if it is operating now. if not a restart is in order.
When your iPad begins to behave strangely these are the first steps you should do to rectify it. Let us know how you go, good luck!!
