ipad 2 will not connect to wifi
Thank you very much
this worked perfectly for me
One of our moderators suggested this might help...
"This has resolved many issues and worth a try.
__________________
Cheers
Col
col.bris, Brisbane Australia
Forum Rules. Please Read.
If there's still a problem, please get back to us and we'll try to suggest some other solutions
I've been also told that to get consistent wifi on your ipad especially if you upgraded to IOS 6 and get intermittent wifi cutting off for a few minutes is to upgrade your firmware on your wireless router if your router does not have the current firmware in place and also clear the cache on all your browsers including safari.
Sent from my iPad 2 using iPF
