iPad Camera Connection Kit - Upgrade voltage hack?
Yes, Openssh is installed. It still says command not found whenever I type umount.
I figured it out...went into Cydia, and diskdev-cmds wasn't installed. Now umount works on both mobile terminal and issh. Now that that is out of the way, is there any way to make the drive automatically mount when plugged in? Before, in iFile, when plugged in the drive would show directly below "disk" the first entry in the column, and it would have a little eject icon next to the label.
OK. I don't understand how you can not have had that installed??? It comes as part of the base jailbreak AFAIK! Glad you got it sorted.
The only reason I installed it is cause I was looking through cydia and recognized it as having been installed during jb before....I tend to remember alot of minor crap like that, but couldn't tell you what I ate for breakfast the day before sometimes. lol
Hi there, i'm having the exact same issue with the 'umount' command! iSSH terminal says 'command not found'! did you finally solve your problem in having the external hard drive mounting automatically without rebooting the ipad on iFile?!
It works wel with usb keys or sd cards, but every time you unplug the hard drive and plug it back it shows 'busy' and have to reboot...
No, it still doesn't automatically mount, but to solve your problem, go to cydia and look for diskdev-cmds and install it. Then you will be able to use the unmount command. And doing that, you don't have to reboot the iPad when you want to mount it again.
