So as part of my ipad's security i have set a pin, as i normally would. Without the case, and i just press the button, i see the wallpaper where i can slide to unlock. With the case on, and i open it, the ipad turns on because of the magnets but it goes straight to the pin (it works like a smart cover). Is there a way to make it so it doesn't go straight to the pin, but rather the "slide to unlock" screen?Sorry, I'm not quite sure what is happening. Do you have to enter the PIN code (for the SIM card) whenever your device is locked by the cover?
