iTunes on two pc's in differnt places, how does that work?
sailorman
Hi,
My new iPad has been synced with iTunes via my laptop here in Texas. When I return to my other home without the laptop and connect the iPad to my desktop there that has iTunes that has only been used to sync my wife's iPod there, and connect my iPad to it what will happen? The two iTune libraries are different and will it even recognize my iPad?
Thanks,
Sailorman
You need to authorize the second computer's iTunes with the same account as you've set up in the first one. Once you've done that, you should be able to at least perform a "Transfer purchases from (iPad's name)" to copy your apps from the iPad into the second computer.
Thanks for that info. What about songs or other files that were not purchased from the iTunes store but just loaded into my iTunes library? How should I get them over to the new computer iTunes?
To be honest, I didn't have that many non-iTunes files (music, photos, PDFs, etc) so my workaround was simply by copying the files off Computer A onto a USB flashdrive, and copied them into Computer B.
Copy your library files from Texas pc onto a flash drive and copy back to home pc library. That's how I move my music around. If you purchased via iTunes just authorize the home pc to your account You don't have to deauthorise her ID
