it worked!!
it worked! i did exactly as u instructed above, and my ipad powered back on!! yaaaayyy!! Thanks so much Rokr!
I had the same issue. Apparently, when redsnow says you MUST have the device powered off, it's not a concrete rule. My ipad died. So I tried the redsnow reboot only but was stuck at the 'MUST TURN OFF IPAD FIRST' step. So I plugged it into the charger for an hour, unfortunately, that then put my pad into a white apple logo with loading icon (sun rays without a sun in the middle) which locked my ipad where I couldn't reset or power off. I then went into the redsnow reboot only process. When it said, power off ipad, I simply went to the next screen where the button pressing directions appear. I followed the steps as if I had turned off the ipad. AS SOON as the redsnow dialog box said that the ipad was now jailbreak rebooting independently and I had the pineapple logo on the screen, I rushed to the outlet and plugged in my charger. After a min, my ipad powered on jailbroken just fine!
Rokr
