Low battery
KC 71
Hi all
I seem to get a low battery after switching the device on
I start with 100% and within an hour im down to 50
Is there anything i can close or take off the ipad that can help maintain my battery power?
Hi all
There may not be a problem with your battery at all, just what that lazy, inconsiderant %age gauge up top may be telling you.
Apple themselves recommend that you should, at least once a month, completely run down the battery and then fully charge it up again. What this does is to realign those recalcitrant delinquent little lithiums, or whatever the little devils do inside, and RECALIBRATE the %age display. That way you should get a more accurate state of your batter charge.
Of course discharge depends also on such factors such as brightness and sound and whether your iPad is syncing automatically etc. But give the "full discharge" suggestion a go and let us know if that improved matters.
Regards, Andrew
Do you actually take it right down to zero or just to like 5% or whatever? My battery gauge seems to be pretty accurate and I only go down to around 5%-10% to calibrate. Just curious.
iPad2 32GB WiFi / iOS 6.0
5%-10% would be about perfect. Would not matter if you took it down to zero. Either way it's what would be considered a "full cycle discharge", a good way to keep the calibration of your battery in tip top health.
I try do do it about every three weeks. Generally, on my usage, I recharge to full every two days when the %age is down to about 35-40% and then every 3 weeks take it down to 10-15%. My battery, well the iPad's, just sings!
Regards, Andrew
