Need help with iPad application installation.
Getting message "waiting" and "paused"
Thank you
Usually happens if you tap the app icon or your wireless is pausing. When App is paused, try tapping the icon if wireless is working.
Welcome to our forums....From Australia. . The issue can be related to poor Internet connection. Try resetting your router and also perform a soft reset on the iPad. Ie hold down the on/off button and the home key at the same time until the apple white logo appears.. Let us know how you go
