Sim card tray stuck, need help please
endikus
Anyone has experienced and managed to release it back, please do share. With step how to do it.
Many thanks before.....
I'm assuming that the usual SIM card release tool supplied with the iPad doesn't work. If you have a SIM card in the tray, it's possible that the upper edge of the card is catching on the edge of the case as you? try to release it and iJayTate's suggestion should work fine because it will hold the SIM card 'down' while you operate the release tool. If there is no SIM card in the tray, then I'm not sure if that will help too much. A trip to the Apple Store might be required.
If you go to the iFixit website you can see a 'teardown' there of a 3G iPad and that will show you how the inside of the SIM tray and the contacts are arranged, making it easier to visualise what you need to do.
However, a word of warning. One Member who had a similar problem ended up damaging the SIM card contacts that connect the SIM card to the iPad and this required a replacement iPad. So be *very* careful.
thank u for those tips, eventually took my ipad to one of electronics shop here in indonesia, and it cost me $45 dollar released the sim tray.
i have the same problem and it annoys the hell out of me. unfortunately taking it to an apple store is not an option since my ipad is jailbroken. any idea how they did it?
well, the other way to do it, i was thingking to cut the edge of the sim tray, by doing this at least you can inside the sim tray then might can release it. but remember before doing that make sure you have the spare sim tray. i did check to one of the apple store in Indonesia. it cost $40 each. this only suggestion. please do be carefull.
Thanks for the tip. I managed to get it out in the end. For anyone else struggling with this, just insert the key at a 45 degree angle and then angle it such that the key comes close to being parallel to the iPad. This should be enough leverage to get the tray out enough for a pen knife or even a kitchen knife to slip in to pull the tray out.
