Speed test apps.
jaba123
Hello, the above name apps, I downloaded one of them. Is they show accurate results. Because some time I had network issues can its help to resolve. Thanks.
scifan57
Regina,Canada
The speed test app I use the most is OOKLA. I find it very easy to use. It gives quick results and stores this results so you can compare WiFi or cellular speeds at different locations or even at different areas of the same building, park, or other area.
You can compare the relative speeds of different networks and be able to choose the best one for your purposes.
Here's the App Store link. https://itunes.apple.com/ca/app/speedtest.net-mobile-speed/id300704847?mt=8
giradman
North Carolina
Well not to be redundant about recommending the OOKLA speed test app, which I also use; BUT, your further question is whether such an app will help you resolve network issues - as to that point, the answer is no unless the app is more complex and has other features that monitor your network and its iPad connection.
So, please provide more information on your 'network issues'? Dave :)
jaba123
jaba123
Giradman, sometime my wifi signal show full but when I browes its too slow i thing from internet provider so we use to call them. It the apps result is good then it's convenient to tell them that ur network run slow. Tks. All of u to advice.
giradman
North Carolina
Hello again, keep in mind that your Wi-Fi signal (i.e. icon w/ the arc bars) may be full but you might still have a slow or even absent connection, so not of much help - this happens to me often using Time-Warner in the USA - thus, don't depend on simply looking at that icon.
The 'speed test' (whichever one you decide to use) will help if your browsing is slow, streaming video is interrupted, or if you are having other internet connection issues. Time-Warner (T-W), my ISP, really is my 'bottleneck' for internet speed, i.e. my average is about 20 Mbps, but I still occasionally get streaming disruptions; so if your DL (down load) speeds are dropping down to under 5 Mbps, then issues may certainly occur.
So, occasional monitor and keep a record of your DL speeds when the connection is good and when poor - might help. Also, if you are getting a poor or absent signal, then reboot your modem & router - I have to reboot my T-W router about twice a week because I just lose the signal. Good luck. Dave :)
jaba123
jaba123
Lot thanks for give me such use tips and explain me.
Kieran2001
Dear jaba123, I see you use tapatalk on your iPad. Would you like me to tell you how to change your signature to part of the message and be anything you want ( of course within the terms of service)?
Kind Regards,
Kieran (This message was sent from a iPad Air)
