The Battery Life of iPad
Is this normal for any other iPad 3G user? Ive been using my iPad for about 2-3 hours and I'm down to 63% is that normal. My iPad wifi only doesn't seem to have this problem but this thing I find is just draining the battery.. Any suggestions?
Under normal circumstances does the 3G iPad loose 11% battery per hour. If the brightness is turned up, it will be slightly faster. So being done by 37% in 3h can be normal.
If however, brightness was low, you weren't using 3G, but wifi instead and not playing heavy games, then the battery drop is a bit fast.
What OS are you on?
