MungaDog
Hi All, In rural remote areas in Australia 3G and 4G Wireless Networks have many areas where service can be in a low
service area with minimum coverage. I am considering installing a 21dBi Yagi directional antenna that Telstra sells and
by all accounts my son who has installed one attached to a 4G 320U Sierra device went from 2 bars to a full 5 bars
continued reception.
My questions are not around the antenna so much more around the connection between a wireless antenna via the coax
cable through to the connection to the iPad4 and (second question) if this can be done, will the iPad pick up the wireless
connection.
If the above cannot be done, what do people recommend???
Regards Maurie
connection.
Regards Maurie
