wingzfan61
And now I've gone as far as creating a new apple I'd and it still says waiting. This is by far the most annoying thing I've ever experienced with ios.
PrincessRendle said:I'm tagging on here too, had this happen twice in a week since updating recently and the buggers won't delete! No X appears to so, I've rebooted it twice and don't know what else to do, and yep, the iTunes account no longer has the download tab, wish I'd kept my ipad1![]()
andymurphy said:I tried absolutely everything to correct this. Most of the solutions offered are obviously from people trying to be helpful but who haven't actually encountered the problem.
The Apps that are frozen on "Waiting" can't be deleted, unlike the other unaffected ones. Rebooting doesn't help, neither does syncing with a PC.
In the end I gave up trying, backed everything up and did a full factory reset.
Inconvenient, but effective.
I've now learnt my lesson and will only install one App update at a time in future.
New ipad 64gb 4hahaG
I have had this happen on my iPad and a simple reset did the trick for me, I have also been able to delete a Waiting App as have others.
Many have tried to download something in both iTunes and the App Store at the same time which will lead to this happening, deleting a pending download will fix this.
What may help some, won't fix the same issue for others.
But like you, sometimes the easy fixes will not work and a restore is the last and only option.
Thank you for posting here your experience and letting us know.
Some apps in Waiting just won't delete. Have you upgraded your iPad to IOS6? Whenever the iPad is updated all apps are then updated to run on this system. So if you haven't updated the iPad this could be a reason that the apps aren't updating.
Did you look to see if you had any pending downloads in the iTunes app?
Let us know.
aixen06 said:Just wanted to say thank you for the information as my issue was with a pending download in iTunes that I had completely forgotten about. Thank you for saving me additional frustration. :thumbs:
