Hi Molly,
I thought that the same-when I started reading all these posts about battery issue. Maybe I did, I do not know--however, I did do the reset as some members mentioned, and it seemed to go back to the normal battery life I was used to prior to the update. I used it quite a bit Sunday-most of the day, Monday night and Tuesday night. On Wednesday, the battery was down to 7%. So I figured I would drain it to 0% since I had not done so this last month. Sure did take a lot of time to drain it down. In fact it took about 4 hours to drain my battery from 7% to 0% today, while playing music with the screen off.
I was very surprised about how long 7% goes with this use. I am sure, if was surfing the web or playing a movie-the battery would have drained quicker...though not sure.
Thank you so much ski...tried the reset and it worked beautifully.Frustration gone........I've been using my iPad since 11am till now 2326hours n it's only at 71%.back to normal.
Clearly whatever issue it had has been resolved...I also let it run a full cycle and recharged it to 100% last night so that could be a contributing factor.
If I may suggest,since this method worked for my ipad2,that people with a similar battery drain issue due to the updated firmware try this before looking for more complex solutions.
Though the reason as to why it happen still remains a mystery to me,I'm relieved it wasn't permanent.
skimonkey said:Hi kagiso-so glad to hear that this helped you! Wow-did you mean 2326 hour? My guess not, yes? However, whatever your usage is, at least it is better than before!
