When I bought mine, the Apple genius said not to use it plugged in. TO let the battery die each time, charge it fully, then unplug. It does indeed shut off when it gets to 100%, so charging overnight is fine, but as soon as it is in use, the charger kicks in whilst it's connected. So, when you see 98%, it will start charging again. I asked him surely it will cut off again and not charge when it's at a 100 whilst I'm using it and he said no, it will carry on charging... only when it's sleeping it stops. Rambling, sorry, but you get the gist. So I'll do as he said... that way it's his fault if he's wrong!
