Anyone go through the process of backing up for refurbished iPad 2? My battery is near extinction. Takes longer to charge than it lasts before next charge. I'm backed up under normal process done automatically, but does that get everything. Then is there a specific procedure for restoring my data to the new iPad? I recognize I will probably need to reset most settings and I'll try to print them out before sending in the original for replacement.
