Battery test
cakueayam
HI guys, you can share your new ipad battery capacity in here so people can compare
(30%brightness wifi+cell on)
Mine
Website browsing: 1% in 7 min
Playing HD games: 5% in 22 min
Standby: 6% in 7hr
Is this normal or i should replace my battery?
Mine
Standby: 6% in 7hr
I'm thinking you are declaring the percentage loss over the given time? So if you start at 80% and do 22 min of gaming you have 75% battery left, right?
For this test to be comparable the usage times should be the same, as should the battery state at the start of every test.
See if they will send you the battery logging profile... I was losing 1% per hour while the device was sleeping, and the logger showed me which apps were interfering. It's a bit of a pain to go through all the data, but it's at least a complete log.
