Battery use for eReader
nealp
Honolulu, Hawaii
I'm using my iPad3 as an ebook reader for about 4 hours every day. After about 3 or 4 hours, the battery goes from fully charged to around 75%.
My question - for maximum battery life
Is is better to charge every night, or wait until it goes below 50% to charge?
Knowing this might significantly extend battery life.
I'm using my iPad3 as an ebook reader for about 4 hours every day. After about 3 or 4 hours, the battery goes from fully charged to around 75%. My question - for maximum battery life Is is better to charge every night, or wait until it goes below 50% to charge? Knowing this might significantly extend battery life.
Welcome to iPad Forums, the best iPad forum anywhere.
You can safely charge your iPad battery at any point in the discharge cycle. It is recommended, however, that once a month or so you discharge the battery to 5% or less then fully recharge. This helps keep the battery percentage indicator properly calibrated so that it indicates the correct percentage of power remaining.
